Allows you to modify the MAC address of an existing MEP.
domain_name |
Enter the domain associated with the MA you are configuring. |
association_name |
IEEE 802.1ag or ITU-T Y.1731 association name. |
mepid |
Specifies the MEP ID of the remote MEP being modified. The range is 1 to 8191. |
mac_address |
Specifies the MAC address for the remote MEP being modified. |
N/A.
Use this command to modify a remote MEP with given MEP ID and MAC address in an existing association. Use the show cfm detail command to verify your configuration.
